nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Mon Jan 28, 2008 7:47 am
Autozone will know what it is.
Run a search, it will explain how to set it up.
If you're still unsure, just have the 2nd O2 sensor moved back behind the cat. The first O2 will stay where it is. Normally the second is behind the precat (which is incorporated into the exhaust mani) in the midpipe, not the main cat between the midpipe and the catback.
