Help with SAFC for KA24E
mountain240sx
Car: 1989 Nissan 240sx Fastback
Hey guys, I am new o the forum...... Heres whats up. I just finished installing my S-AFC II in my 240sx with a SOHC. I was wondering if anyone had any suggestions for a base tune. All I have is Injen cold air intake, Hotshot header, custom 2.5in exhaust, and grounding kit. I am going to swap out for SR injectors, Nismo FPR, and Walbro fuel pump and I am getting a MSD SCI ignition box and Blaster SS coil. If anyone has any input of how I should go about tuning it I would be greatful....Thanks guys
goj_cloud
why would you need a safc if your not running a turbo
180fan
Car: 89 fastback
cuz you can squeeze out a little more out of the ka or manipulate your fuel to do different things like helping pass smog or increasing mileage with a leaning out, etc.
nissanman04
Car: '90 240SX, '95 Subaru Legacy
you're gonna need a wideband to see how lean/rich your running. and even if you get it tuned, i cant see it making too many extra horses.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
If you're going with the 370 cc SR injectors, why not upgrade with a wilder cam to take advantage of the increased injector flow.
These two together should give you a nice HP increase.
goj_cloud
ah
180fan wrote:cuz you can squeeze out a little more out of the ka or manipulate your fuel to do different things like helping pass smog or increasing mileage with a leaning out, etc.
ah i didnt know that
480sx
Car: 1996 Pearl White 240sx
The ka has a realy rich fuel map, so a safc can help fuel econ and horsepower to a degree. But tuning without a Wideband is a bad idea, you could lean your engine out to much and do dammage, or blow it up. Id recomend a Zeitronix unit, i recently put one on my sr with safc-2 and the data logging makes tuning easy. You can pick up the baseunit for a laptop for about 300 or less.
goj_cloud
you can get it dyno tuned cuz they should have a wideband
Iscariot
Car: 1995 240SX
yeah either use a dyno or get a zeitronix...widebands ftw. narrowbands are really vague and you can royally blow your engine. ask me how i know
