JAAS »
https://forums.nicoclub.com/jaas-u126544.html
Tue Mar 17, 2009 10:29 am
All the signal wires on the Active System are run from the headunit to the 3 amps (1 for the rears, 1 on each door for the fronts)..
If you want to bypass them I believe the easiest way is to cut the wires as they enter the amps and connect them to the new speakers..
These are the colors on the headunit connector, knowing them you can test the wires from the connector at the amps with a continuity tester to match them..
Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Good Hunting..
