MagikDragon wrote:
When is the last time you have seen a bolt in cage in Rolex cup, NASCAR, NHRA, NDRA, World Challenge, Formula D, Redline Time Attack, or any other recognized racing clubs? NO, Weld in caged do not shear at a small bolt, yet they distribute the forces over the entire area of the tube. Weld in cages are still bolted to the floor of a unibody car. but do not flex like a bolt in cage anywhere else in the structure. Try and prove that a bolt in cage is stronger and you are fighting a battle you will never win.
A pre purchased 4 or 6 point, there is no better than weld-in.
This is being moved to the road racing forum for better coverage by experienced guys.
He wants a cage to drift not road race. D1 does recognize a cusco cage as a legitimate cage. I could care less if NASCAR, NHRA, or FORMULA D recognize. I don’t consider left hand turns a legitimate motor sport, straight line racing is not my cup of tea, and I don’t drift for the paycheck.
nismofa g wrote:
LOL anyone who thinks a bolt in cage is legit needs to go back to putting apc steering wheels in their geo metros because anything more is over your headQuote, originally posted by SlipnSliden 240 » This thread is full of morons.
especially you d!ck****
cusco is a cage if you like to look good in shows, autopower bolt in is barely above that level
AT LEAST get a weld in autopower or etc
your best bet is a custon welded in cage from a real shop, youre in vancouver so im not quite sure exactly who youd go to
I like it when you talk dirty d!ck****
A D1 driver with a APC steering wheel in a Geo Metro could probably out drive you. I dont know how many times I need to cover the fact that a cusco cage is a D1 approved cage. On a side note Autopower cages fit like $hit.
lofapoo wrote:
Do you mind explaining how the hell a bolt is stronger than a weld?
Seriously, if a bolt-in cage is better than a weld-in, then why is it that most (if not all) professional racers WELD their cages in?
This should be good.
I will get there.
nismofa g wrote:
not only that, but how many chassis do you know of that are bolted together? i can start naming chassis that are welded together anytime (basically any car short of a carbon fiber monocoque formula car)this should be interesting
If the factory spot welds with body glue are so superior why did I waste my time stich welding my car?
AmoebAssassin wrote:Quote, originally posted by SlipnSliden 240 » This thread is full of morons.
You really should reserve your judgment of others unless you are absolutely sure of the validity of your arguments.
Quote » Comparing a sti chassis to a 240 chassis is like comparing apples to oranges. One guy suggested weld in is better and everyone jumped on his nuts like hookers out of work. It is proven that the shear strength of a bolt is far greater then the shear strength of a weld.
Take a second and think what you're talking about. The shear strength of a bolt is indeed stronger than the shear strength of a weld -- but too bad that welded roll cages have welds that are loaded in tension, not shear. In our amateur shop, we've laid beads that we have physically tested to be ~95% the strength of solid, unwelded steel. That was done with a MIG, not a TIG -- a TIG weld will be a couple percentage points stronger than a MIG weld.
A bolt in shear could be stronger than a weld in tension, based on the quality of the weld and the diameter and grade of the bolt, but take a look at any bolt-on cage -- the tabs which the bolts engage are always planar tabs that are -- you guessed it -- welded on to other bars. The disadvantage of the bolt-together cage is that if the tabs are loaded with a non-planar force (i.e not in tension or compression), the tabs will fold at the weld, causing them to fail. A tube welded to another tube would not exhibit this failure mode unless the tube is kinked first.
Quote » Safety 21 or Cusco (same company) is a legitimate cage in the D1 circuit. I don’t know how many of you are driving on that kind of level, but assumption leads me to believe that if so you wouldn’t be a member of NICO. A 4 point cusco saved a guy in a S14 roll over, why wouldn’t a 7 point cage do more?Quote »And yet, bolt-in Cusco cages fail to pass tech in just about every European and north American motorsport, INCLUDING autocross, which typically occurs at lower speeds.
A bolt can be installed while keeping full interior a weld in on the other hand is more difficult to achieve. I have saved enough weight in my car to keep the extra couple of pounds of a full interior and run a cage, I like the appearance of a complete car. I added a cage for one reason chassis rigidity you can not tell me that a welded cage will be in sturdier then a bolt in. It is proven.
Proven by who? Can you show me any numerical evidence to support your claim that a weld-in cage is inferior to a bolt-in cage?
Actually, unless the holes in the bolt bosses and bolt tabs are reamed to EXACTLY the diameter of the bolt, Then chassis flex cannot be stopped with a bolt-in cage -- the cumulative amount of slop in a typical slip-fit, un-reamed, bolt-together joint is probably on the same order of point displacements caused by chassis torsion. Weld-together cages have no slop.
Ok lets talk tensile strength
The tensile strength of an average weld is 70,000 psi The tensile strength of a SAE grade 8 bolt is rated at over 150,000 Psi
This would result in the welds of the brackets the weak points of a bolt together cage.
Thanks to Dustinmikl(a member here, a quick search brought me back to the last thread this was discussed in.)
.Grimace wrote:
hey slipnsliden 240, reading > you. i said i didn't want my cage held together with bolts. it doesn't matter if its a 240 or a sti it's bolted together. i would use a safety 21 cage because i do know that bolting it to the chassis is safe.
Clarity > you. You said nothing about whether or not you wanted a cage held together with bolts. You said "example, want this being your safety?" Then proceded to present a picture of a STI with a cusco cage. The OP said nothing about a cage for a STI he wants ideas for his 240. Cusco and safety 21 are the same company.
racerbob4 wrote:
The Cusco cage doesn't even have a crossbar from the upper drivers side to the lower passengers side on the main hoop. The hoop takes the brunt of the load on roll over.
This is a 4 point cusco roll bar, not a cage, it held just fine.
My goal isnt to look like a jack@ss. My idea is to pass some information around so that people like the op can make educated choices. He does not need a weld in cage. That is over kill for him and 90% of this forum. I am just trying to convey that message
