180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Mar 21, 2005 1:03 pm
#1. tighten the belts to make the fan spin#2. personally I've switched all the cars I service to the red Toyota coolant. It's good stuff. Otherwise, I'd just get some regular green prestone and mix it with distilled water (I use alhambra as they don't put any salt in it which can corrode aluminum).#3. Is the belt to the power steering pump tightened? I'm assuming this "mechanic" didn't tighten this one either.#4. how long has it been since your gear oil change? If this "mechanic" is as bad as I'm getting the impression he/she is you might want to change gear oil. Take it to a shop (or do it yourself) and have them change your gear oil with either Redline MT90, Valvoline Synchromesh, or my personal favorite Motul Motylgear. If none of those above are used, make sure they use a GL-4 spec oil, GL-5's are not good for your transmission.
