help with rb20 swap its gone crazy!!!!!
elementon24s
Car: 240sx rb20det
08 honda element on 24s
Ive spent days looking and reading posts "im new to the rb20 world and this is my 1st 240" and just cant seem to find out what’s wrong with the car. The motor came out of another car and was working just fine not having any of the issues that I am so im thinking maybe in the wiring or something. When you first start the car everything is fine you can get down on it no problems under full boost but after about 3 or 4 min even if your just driving it normal it feels like your getting fuel cut. When I first put the motor in the car it was running open down pipe and last night I put it back on to see if that would help whatever was going on with it but it didn’t. as soon as you get into boost over 3500 it cuts out anything over about 3psi. the car has a stock down pipe and 3 ½ exhaust and it has been tuned and has a 255 fule pump other then that and a hks filter its pretty much stock. The plugs have been changed ive checked the ecu and it blinks 5 and 5 and that means everything is ok. But the funny thing is when it starts running like crap after a few min the red led on the ecu will randomly go on and off when its not in test mode. Ive watched it and it its not blinking out a code or anything it total random. I have also done a pressure test and it help 15 psi for about 15 min before it fell to about 6 it shouldn’t be boost leak. Then I was thinking maybe coil packs but it runs great when you first start it weather its cold or warm but after a few min something happens feel free to give me a ring if you think you can help i know time is money i have no problem paying to get this fixed.
