Alt.ImaCoupe »
https://forums.nicoclub.com/alt-imacoupe-u104112.html
Mon Oct 05, 2009 12:33 pm
I installed my new Racingline RSB today, but I'm not sure it's right because it seems impossible to get the endlinks into the stiffer set of holes. I considered the possibility that it could be upside down, but when I tried to flip it, the bar seemed to interfere with the lower control arm.
The way it sits now, the bar follows the control arm, and then curves vertically down towards the endlinks. I have racinline's endlinks also, and I've adjusted them to be as short as possible to get the bolts into the outer holes.
Can someone who has installed this bar confirm if this is correct or not? If so, how did you get the endlink bolts into the stiffer holes? Do I need to preload the suspension a bit? I had it up on my buddy's hoist, so everything was fully unloaded during the install. Pictures would be great too if anyone has them. I looked for a write-up but couldn't find one.
Some instructions from Racingline would have been nice also.
