help with r32 GTR plz
nayrGTRr32
Car: 89 R32 GTR Skyline
hey guys, jus need some advice or opinions on rb26tt. it has a slight miss at idol and under mid to high boost it surges. Am thinking its the standard coil packs. open to suggestions. on a low budget. cheers guys
qwertyz
Car: Nissan S14 AWD
find out which cylinder missing check coil for proper operation, check compression, check injector pulse, if all good check for boost leaks (or check for boost leaks first had them on my rb26 ran like crap)
nayrGTRr32
cheers mate. appreciate the help. i know compression is all good as i tested it when installing new engine. how do i check injector pulse? can i do it myself with no gadgets or? as on a low budget and car is currently unregistered. just wanna have it running sweet before i put it on the road.
qwertyz
Car: Nissan S14 AWD
noid light from Autozone rent or buy (i think per one is 6$) will check the pulse on injectors. OHM the injectors also
check coils for proper operation with this tool Image
should jump 30 thousands (tool is like 10 $)
if all good look for BOOST LEAK
is it a gtr or you just put the motor in something else?
nayrGTRr32
no its an 89 r32 GTR. all original. engine swapped it as when i bought it cheap, original engine had ugly knock in no6 cylinder.
qwertyz
Car: Nissan S14 AWD
i c.... if you need help pm me i will try to walk you through it
