3rdegree »
https://forums.nicoclub.com/3rdegree-u42850.html
Fri Jul 07, 2006 5:03 pm
After many hours searching this fine forum of yours I am still having a problem with my 1989 Q45.The car has sat for the last four months & now will not start. I have gone over the car fault finding & can say it seemes to not be getting REF & SYNC pulse's. I have got this far but not too sure where to look at now. Is there a known problem with these cam & crank angle pickups?I have come to this conclusion from checking injector & ignitor triggers while cranking, the tacho does not budge while cranking & the fuel pump isnt working.
I tried jumping the fuel pump but that still doesnt seem to pressurize the fuel rail or makes any noises.
Are the crank angle pick ups 3 wire? Does anyone know if the pins should be 8volt-Signal-Sensor Gnd???
Would appreciate any ideas as after many hours of trying Im not getting anywhere with it.
Thanks.Murdoch
