Q45 brakes will clear stock steelies... It's rumored that they won't fit teardrops, though. I haven't tested this or not.ray666 wrote:i was thinking of doing this swap. i just don't know if my wheels can handle larger calipers. there 16" xxr's with 0 offset. think they'd fit? i guess i could go j30 if the q's don't work.
Dont use a Z32 BMC with the Q fronts. The bias is set up for 4/2 pistons. I have heard of people using the Z31 BMC before, some even use it with Z32 brakes.LambJerky wrote:If you have a Q45 BMC, it will work, not sure how difficult the job is.
Z32 BMC is a good option too, I have one sitting around somewhere I'm gonna use on my s14. From the looks of it it may be tricky but not difficult, so I would assume a Q45 is not much more difficult.
Oh, no that is not what I meant. I didn't mean to say to use the two together. I was only comparing the difficulty level of installing them.OutToWinPAHC wrote:
So use a S13/S14 BMC or get a Z31
I stand corrected on using Q45 BMC with Q45 calipers. I was only going based on what I have read from other builds with this setupmatt4pl wrote:Q45 master cylinder won't work...
confirmedAZ89two4Tsx wrote:Ok here.
- Keep your stock master cylinder, it will work fine with Q45s up front
- ONLY use Q45 rotors. Don't chance something like that, they're cheap
- Make sure you get the caliper mounting bolts. They are soooooo hard to find, and you'll have to order them from the dealer. J30 bolts will work too
- Get the rotors drilled at a machine shop, don't use a drill
- They are bolt-on other than the dust shield
- Q45 brakes fit almost every wheel out there. Much lower profile than Z32 onesk
Ding ding ding!diggles240 wrote:Z31 has a better brake bias supposedly. I do believe a lot of people use it.
It is very simple. If you want to lock up your brakes, it is very easy to do (without ABS). Do not forget that stopping power is very dependent upon tire grip, i.e. crappy tires = easy lock up.ray666 wrote:i have to ask, how you are locking your brakes so easily? i haven't heard of anyone having that kinda trouble.
Maybe you need to rebuild or service your calipers, my cousin had a similer problem and he needed to rebuild them.rico05 wrote:I get my fronts to lock up fairly easy with the standard BMC, so I would be very cautious with upgrading.
Not true at all. Do not shy away from the Q brakes because of the increase in stopping power. By my statement, I meant only that one can lock up the brakes if they want to (not like you would want to do that). You just have to learn how to properly brake.ray666 wrote:i guess i'm gonna go j30 then cuz i don't have abs
