OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Mon Aug 10, 2009 6:27 am
If your sure it was wired correctly you may have a bad fans.
Do the fans spin freely when spinning by hand? Is so move on, if not the fan motor is bad. Try connecting the fans right to a battery only to test, no relay. If they still sound funny, then it sounds like a DC motor brush or even fan bearing issue. If not rewire the fans, I suggest using the Perma--Cool fan relays. They are beefy and rated in RMS not peak current :bow down
