HI Guys!
I am considering ordering a set of 22 inch Forgestar F14 for my 2010 FX35 RWD.
There are quite a few width and offset options with this wheel.
So here are my options. Will I have to worry about rubbing or modifying fender on 10.5 if I don't lower ?
If I decided to go Semi concave should I do the 9 or 10's ? The retailer was recommending 9's and running 275 or 285 tires. The stock/inventory on 10's is low which is a concern as far as wait time.
22" SEMI CONCAVE
22x9.0 offsets from +18 to +57
22x10 offsets from +31 to 70 (Low stock may be a 2-3 month wait)
22" DEEP CONCAVE
22x10.5 offsets from +10 to +49
Which tires have the most options? I am noticing as you change size and profile some sizes have 4 tire brands to choose others less
For example TireRack has the following tire options/brands for each size
We found (6) tires for: 305/40-22
We found (4) tires for: 285/40-22
We found (6) tires for: 275/40-22
We found (1) tire for: 275/35-22
We found (2) tires for: 295/40-22
