I'm thinking the 1.6 is very similar in design. On the 1.8, the filter sits sideways but if you change your oil fast enough, it won't be dry when you start it back up. And yea, a little bit over the full line won't hurt it. There's some room for error but usually things can happen if you overfill by half a quart or more.daan wrote:filling the oil filter up before attatching it will help, too, instead of screwing on an empty one. Depending on if the filter is positioned well for this, I guess... The oil pressure comes up quicker than if the oil pump has to fill up the new filter first. And a small amount over full isn't as bad as too much, an X-GF put 5+ quarts into her car that took less than 4 and drove it for weeks before I checked it, and it ran fine for years after that...
