Help with offset for 07 M45
NICO's V.I.P. styling forum.
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Hi guys,
First time looking into the vip section and need some help for a friend. He's got a 07 M45 sport and wants to get set of works wheels in 20's. Whats the lowest offset possible with bit of roll/pull and stretch. Hes going coil overs.
Thanks guys,
Jonathan
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Well considering the OEM wheels are 50+ offset. I would suggest 9-9.5" with 30-35.
JonathanPrem
He planning on doing 20x10.5 30-25+ offest and 9,5 with 30.
RED_DET
Vendor
2011 Infiniti G37x
Good luck with a 10.5" with 30-25 offset. Hell I can run better offsets on my sedan than on the M and I'm not fitting a 10.5" properly with 30-25 offset. You would have to be extremely low and ridiculous amounts of negative and ungodly stretched tire.
skim35
Car: Infiniti M37 Sport
When I had my 06 M35 sport
I had Work T1S 9x10 20's and the front offset were 35 and rear i think 35-38?
and Slammed on JIC vip coilovers ran 225x35 Falkin front and and 255 35 rear.
Also I ran a 5mm spcaer in the front and a 10mm spacer in the rear and didnt have to pull.
My rear tires were half way tucked under the fender and in the fron barely tucked under the fender
NO RUBBING! Loved it!!! :chuckle:
Return to “VIP Forum”
