help with ODB codes P2128 and P2138
tlsmith1999
Hello,I have a 2004 G35 Coupe with the check engine light on. The diag codes are P2128 APP sensor circuit high input and P2138 APP sensor circuit range/performance problem.
Can anyone tell me how to trouble shoot this problem, or know a good resource to do so?
I can't really afford to take it to the dealer to get it fixed right now, and am hoping someone on here has some ideas I can try my self.
Thanks
Bigjoe347
Car: 2005 Infinti G35 Sedan
tlsmith1999 wrote:Hello,I have a 2004 G35 Coupe with the check engine light on. The diag codes are P2128 APP sensor circuit high input and P2138 APP sensor circuit range/performance problem.
Thanks
Welcome to nico!, did you try searching on google for those codes? you never know what you might find out there. Or also look in your owners manual. Thats about all the help i can give you though.
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Its going to most likely be a bad sensor BUT check your fuse box for blown fuses and check the wiring at the sensor. You could try cleaning the sensor with electronics parts cleaner.
zozoka1212
Car: 08 Infiniti G35x
this should help you.
http://phatg20.net/index.php?o...&id=9
zozo
