HC and CO have been in spec in every test. It has failed NOX at 15 and 25mph dyno test every time. 15 has always failed worse so I'll just give those specs to keep it simple. Car had new shiny AIV valve when I bought it. Timit is dead on at 15btdc.
NOX limit for my car = 800ppm
1st test:-NOx = +-2500 ppm
2nd test:-Found and replaced broken vacuum line going from BPT valve to EGR valve.-Checked all Vacuum lines and replaced any that were questionable.-Tested EGR valve and BPT valve according to Chilton's manual. Everything checked out.-Replaced O2 sensor and changed oil.-Sent injectors off to be flow tested, rebuilt, and flow tested again. No difference after rebuild. All are in within stock spec.-NOx now at +- 1200
3rd test:-Replaced Cat.-NOx now at +-1300
The car is completely stock (except KN filter in stock box) and runs fine and I have am out of ideas as to where the problem could be. Engine has 125k miles. Like I said an old man owned it before me and probably never took it above 3500 rpm. It even blew a fair amout of carbon out the exhaust when I redlined it the first few times. I have it scheduled for diagnostics at a local shop in a few days. I have never had a car in the shop before and would like to avoid it. Any ideas?
Thanks
