SullivanRacing06 »
https://forums.nicoclub.com/sullivanracing06-u63212.html
Tue Dec 09, 2008 5:47 pm
so to speed everyone up on my situation, i ordered a NEW rb25det transmission from nissan japan, got to my door step, installed the transmission, filled it with 75-80 non synthetic gear oil, drove the car for tops of 10 miles and BAMMM! shifter stuck into first, towed the car back to shop, pulled the shifter out n noticed the lower shifter bushing popped off the bottom of the shifter, replace the shifter bushing, transmission goes into first no problem, shift into second and when you try to let the clutch out the engine tries to die out and then whe you shift from 2nd into neutral position its in reverse! im so pissed off that i just dropped x number of $ into to a brand new transmission and it fuc#$ up on me like this, contacted the importer tonight n they said to send it back n theyll look at it and see what nissan can do, thank god i payed thru paypal but why the hell is a brand new transmission gettin stuck into gear like that? sounds like a shifter arm broke? popped outta place?
whats nissan call for for gear lube weight? 75-80 80-90?
holds 4 qts rite?
