I rebuilt my transmission about 10 years ago. It was a manual, so I got a kit with bearings and syncrhos. I got the kit that used Timken or maybe NSK branded bearings. Ebay versions had generic. I ordered it through the internet and don't recall where but it was some sort of transmission rebuild place and cust. service helped me identify the kit. Most everything matched except for maybe one bearing or maybe reverse syncrho IIRC. Now, there were several versions of the manual transmission and most had similar parts in the kits, with just one or two odd parts being different. So, I'm saying, kits for a very near same transmission, might have most if not all the parts you're looking for. Here is a rebuild kit for a similar transmission RE4F03A that may or may not have parts you can use in yours:
http://www.auto-repair-manuals.com/Impo ... fgodMBMLKQ I would spend a bit of time checking cross-compatibility if you can, before purchasing. Of course Nissan Dealerships will have all the parts, not likely in a kit, but maybe. The dealership will be expensive in comparison, but certainly the correct bits.
