Help with my car alarm
EG240SX
Car: 1989 Nissan 240SX SOLD
I just recently bought a 1989 240SX. Not the last owner but the owner before installed an alarm system. My uncle WAS going to help me install a new radio today but never showed up and I disconnected negative from the battery. I tried reconnecting the battery and now the car alarm goes off. Can someone help me by telling me what I should do? I don't want to annoy any of the neighbors, they call the cops for anything.
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
I believe you need to remove the fuse, reconnect the battery, and then use a pen to push the reset button on the bottom of the alarm controller. But that all depends on the manufacturer. I suggest looking up their website or give them a call.
t34stud
Car: 240sx se
is one of your doors locked and the other not locked?
spank044
No, I don't even have an alarm, just going by past experience.
KADET:S13
Car: 1990 240sx ka24de
What you could do is, connect the battery (alarm will be going off) then run quickly into the car and put key into switch and turn the key...happend to me when i was putting a battery into a friends car. Good luck.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Unbolt the lower dash on the driver side. You'll see a black box that's hanging out in there. If you just disconnect the wires from it you should be all set.
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
Yeah, the alarm on one of my 240s is sensitive as F@$@! my 240 with the stock exhaust just going around the yard sets it off, it's ridiculous.
As for the neighbors, yesh i know what you mean, looky heres...
http://www.youtube.com/watch?v...ex=10
EG240SX
KADET:S13 wrote:What you could do is, connect the battery (alarm will be going off) then run quickly into the car and put key into switch and turn the key...happend to me when i was putting a battery into a friends car. Good luck.
i did what u said it worked thanks only thing was i had to jump my battery but thats ok i just recently bought the car thats why still trying to familiarize my self with the car
KADET:S13
yup, no prob, cool! no more noise! haha
