mss5413 »
https://forums.nicoclub.com/mss5413-u20429.html
Thu Apr 03, 2008 1:11 pm
Also, you can check for a drain on the battery by getting a cheap test light from a parts house. Make sure all accessories are turned off, disconnect negative battery terminal and connect the test light between terminal and battery post. Alligator clip of the light connects to cable terminal and test light touches battery post. If it lights up, then there is a drain and you must pull the fuses one at a time to isolate which circuit is at fault.
