Ronpatz wrote: Not sure if this is the right forum for this, but I'm hoping somebody may have a solution. I have a 2004 Infiniti QX56 with around 100k miles on it. Up until these past couple weeks, I haven't had any problems with the cara as it has only required standard maintenance. That has changed lately.
You are in the correct Forum, but please complete your profile.
One needs to realize that "standard maintenance" is the minimum required to get the vehicle beyond standard warranty period so the big stuff fails on your dime and not on theirs.
As an example, have you ever mechanically exchanged your ATF? Added an auxiliary ATF cooler? Checked its color smell and level?
Not your problem now, but will be soon. Did the dealer measure fuel pressure? If your truck (separate frame and body) is like the VK in the F50 Q45, the filter is in the tank, but It surely needs changing by now? Ever run BG44K or Redline SL1? Iso-Heet? Do you have ethanol in the fuel in your area?
