help with moter swap
globe3
Car: 1993 nissan harbody
has any one swap a ka24de from a nissan 240sx into a nissan hardbody. if so what did you do to do it.
seang
Car: Ford Fiesta ST
The 240sx oil pan is front sump compared to the truck's rear sump layout. There are a few other differences, too; but I don't want to say anything that will turn out to be absolutely wrong--again. I know for a fact that it has been done before, though. Do you just want more power?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
search the forum. This question comes up frequently and it has been covered.
srvska
Car: 2000 frontier
if youre gonna do that just swap a frontier ka, easier and pretty much the same minus a few minor details.... the biggest difference is the intake, and a frontier ka is basically the same as the s14 ka...
driftin_sr20det
Car: 92 Coupe
Yunno I asked the same question and didn't find much, other than it doesn't fit haha... So I decided to do it anyways. If you can't weld and fabricate its not the project for you. You will need to customize the truck pan by cutting the front off of it and melding it with the 240sx oil pan front. Fabricated a rear sump pick-up as well, and I'm using the 240sx engine wiring harness seperate from the hardbody harness and running a 240sx cluster also. Not completely finished yet but I got the hard stuff done, now its just the tedious sh#t haha...
