HELP WITH MAX
ahmad3051
CAR IS VERY HARD TO START WHEN COLD. I AM TALKING 5 ATTEMPTS BEFORE IT STARTS.
ALSO THE CAR WILL NOT LET ME GO OVER 2 K RPM. IT FEEL LIKE I AM HITTING A REV LIMITOR.
I HAVE SWAPPED ECU' , KNOCK SENSORS, & MAF.
WHAT ELSE SHOULD I DO?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
First, turn off the caps lock...
Second, I'm assuming this is a Maxima, since you posted in here.
What year is it?
Maybe, coil/coils IACV, EGR valve, did you check the wires going into the MAF? Is one possibly broken?
Does it sputter, like a clogged fuel filter, or dying fuel pump? Have you checked fuel pressure?
Battery have good AMPERAGE??? Most of the time people check volts, but what about the Amps?
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
if you cant do more than 2k on rpms, then that usually means there's a prob with the MAF. i understand you changed that out, but here's the catch. i went through 4 MAF's (thank god for warranties) until i realized it was the wires going into the plug that plugs into the MAF. they were backing out, so i got them resoldered (sp?) into the plug and voila. done.
ahmad3051
IT IS A 96 MAX.
I DID CHANGE THE FUEL FILTER. I ALSO CHECKED FOR GOOD VOLTAGE AT THE MAF AND IT WAS GOOD. WHERE DO I GO FROM HERE.
ahmad3051
HOW DO YOU CHECK FUEL PRESSURE?
Beancooker
Please turn off the caps lock. It's like your yelling at me.
This should help:
WDRacing
You know whats cool about all caps though?
Absolutely nothin.....GHEY.
00_Altima MD
Car: 2004 Sentra SE-R Spec V
it sounds like you have a cam sensor that went out on you. generally when a cam sensor goes out the car will go into what is called limp home mode which will basically is a fail safe mode and will also give you delayed start b/c it does not have the signal. see about pulling the codes and if there is a stored code for the cmp sensor then i would inspect the harness replace the sensor if there is nothing obviously wrong with the harness.
