miamiheat3332 wrote:Id check how the springs are seated in the rear, are you sure the put on the thick peice of rubber that goes between the top of the spring and the mounting location? It looks like it could be missing that and thats whats making it so low. Mine didnt look close to that, i would jack it up, take off the wheel and take a quick look.
Also, put your fingers between the tire and the fender flare in the rear, tell me how many fingers you can fit between it.
rear = 2 fingers + maybe 1/4 of another finger at most
I am pretty sure that the rear was installed perfectly since we had guidance from a mechanic. The thick rubber is in place and we were careful when jacking it down to see the springs going down where they were supposed to with the thick rubber.
but I think we screwed up somewhere in the front!
I left my path with my friend this week so that he could take it to his gas station workshop and ask the mechanic to check it carefully. Hopefully the problem will be fixed because it looks horrible :/
