Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Mon Feb 13, 2006 3:26 am
My right front wheel on Lola is about 3/4" further back than normal. The culvert looks a lot worse off too. The rim and tire took most of the impact, but it appears the suspension has relocated without leaving a forwarding address.
I took her to the local shop, and they confirmed that the lower control arm (transverse link)is bent.
I ordered a new transverse link from Joe and attempted to put it on this weekend.
I was unable to remove the ball seat from the original one, even after beating prying and cursing.
While I had it off, I compared it to the original. They look identical. I know a 3/4" difference in the end of a 20" control arm is hard to tell by the eye, but I am really concerned about the front suspension member and tension rod brackets. The lower control arm looks beefier than the front suspension member.
Here are my questions:
1. How does the ball seat come off? Do I need a puller?
2. Since the car has no adjustment in the front caster or camber with factory parts, do I need to replace the suspension member, or can this be straightened?
3. Has anybody had a similar experience?
I am really wishing I hadn't sold Layla, now.
Here is a picture of the ball seat (it is in red) and transverse link (it is in blue):
