$68 sure sounds like a better deal than a couple hundred to replace the block entirely, which if it has blown piston rings you may have other issues to look into like replacing the head gasket, burnt pistons, a warped head or whatever else could be wrong.
As far as how to replace the bearings just search the site, I'm sure there is a write up about it since this is one of the issues that comes with having a KA. I'd also suggest you get an FSM, there are a couple of links around for this too. If you noticed it after drifting then it's definitely spun bearings, that's how I blew up my second KA. It's likely from oil starvation. As far as tools and not knowing how to replace the parts, I'm sure you know someone who knows how to work on cars and has the tools and space to do the work that is willing to help you out. Where do you live, I'm sure someone on here would be willing to help out a fellow NICOnaut if you live close by.
