Indy240Spaz »
https://forums.nicoclub.com/indy240spaz-u26888.html
Sat Apr 02, 2005 6:35 pm
Alright, have a BIG problem...
I was out tonight messing around, pushing it pretty hard but not over redline. Was doing fine until I stopped at a light and I noticed that my car had died. Started up just fine, so I turned into a parking lot to check to make sure there wasn't any smoke or anything coming out.
Everything looked fine until I pulled the throttle up a bit and I heard some really loud ticking coming from my crankcase. Checked the oil real quick and I noticed that it was low, so I tried starting it up and driving over to the gas station.
Didn't even get it out of the lot because the ticking was so loud that I was scared to drive it any further. Dumped a quart of oil into it, then started it back up and pulled the throttle a little, ticking was still there. Once I got into the car, I noticed that my idle was jumping around, almost dying. Decided to chance it and drive it home and the sound just got worse, the car dying when I let my foot off of the acellerator. Starts up just fine, just stalls out when I take my foot off, and it's ticking REAAALLLY loud. (Girlfriend says it sounds like a woodpecker ). Then when I was about to turn onto my street I could hardly keep it running, stalls out if I'm not flooring it, and when I am, I'm CRAWLING.
Any ideas as to what may be up? Fixable or should I just pull the engine and swap it out?
EDIT: It's a 92 engine, btw.
Modified by Indy240Spaz at 12:16 AM 4/3/2005
