hkchuen »
https://forums.nicoclub.com/hkchuen-u43266.html
Wed Aug 23, 2006 2:48 am
I am a little confused now. Here are the information, according to the dealer, that I summarized:
[1] There is an engine code (as can be seen from the figure attached above) for knock sensor, and for "Injector-Open" (it says 4 times, I am not sure what it means)
[2] The dealer says that it passed the ohm test, i.e., each injector has the right resistance.
[3] They say that the "seats" are bad, for injector #1, #3, #4, #6; probably they mean the "O-ring".
Now my confusion is: Does it mean I should replace those injectors, or only their o-rings?
