1. Option for 6 CD changer (as in sedan) listed as option in G37 manual but can't find option in configuration--is this available with the G37? Likely they just "lifted" text from G35 manual!2. Says SACD (Hybrid CD-DA) can be recorded to Music Box? Does this mean the unit will also play two-channel SACD's?3. Can only record actual music CD's and appears can't select songs, must record full CD then delete tracks???? 4. Why such a good sound system with the upgrade (great DAC's, etc.) but only relatively low MP3 option for recording to music box?
Conclusion: too much work to record most of music library to Hard Disk (other than jazz/classical albums that whole disc is used) and bit pointless if fidelity is reduced to weak MP3 specs! Have to rely on IPOD and/or flash card to get full libraries from PC to this stereo system. Hope a software upgrade is coming for the Gracenote system. Quite a dissapointment and hope 6CD changer option is available for trunk for all my recorded CD's!
