Help with interior lights
Cha
Could someone tell me which leds i need to order to change my lights out for the dome, map, and trunk. there seems to be so many part numbers floating around and one site claimed i needed the same light for all three and wasn't sure that was accurate.
http://www.v-leds.com/Shop/Con...47244#
The link shows one part I thought might work for the dome but I wanted to make sure they would also work for the others before I ordered a bunch of them. Thanks.
SenorPayne7
Car: 2008 Black SL AWD Nissan Rogue
BUMP! any one know the answer?
Leo2005
Just checked OSRAM SYLVANIA website and DE3175 will perfectly work. For brighter results get the panel of leds. Not the bulb. As long as I remember the bulbs next to the windshield in dome light are 194 not 3175. If you order this set of leds then you definitely find the right connector for yourself since they offering a few different connectors for the same price:http://www.v-leds.com/Interior...html
SenorPayne7
thanks leoooooo! has anyone put LED's in their car??
zengshengliu
Car: 2008 Nissan Rogue SL
My car is full of led lights front map light is 168center dome light and trunk light is 3175I got two led strip lights which go from front to back of the carAll my exterior lights are leds too
Leo2005
Yep. I should describe it earlier. The size 194 is also referred to with other numbers. The 194 is equivalent to... 194 = W5W 147 152 158 159 161 168 184 192 193 259 280 285 447 464 555 558 585 655 656 657 1250 1251 1252 2450 2652 2921 2825. These are all the same bulbs.
Return to “Rogue Forum”
