Help with Interior LED Lights
All things Altima Coupe.
Eric Noa
Car: White 2011 Altima Coupe 2.5 S 6MT
Hello everyone,
I want to change out the interior lights of my 2011 A/C to LED's but Im a bit confused. I've been reading on here but I can't find the right answers. Im not sure what the bulb sizes are? Some people say that 194 for all the interior lights except the dome light but I found on http://www.sylvania.com/ConsumerProduct ... mentGuide/
that the bulb size's are as follow:
Map - 175
Dome - 175
Step/Courtesy - 194
Trunk - 158
License Plate - 2825
Are these corrected? if so how many do I need of each? For most I will need 2 bulbs correct? Another thing is the color, Im looking for a crisp clear white color, not the yellowish color from the stock bulbs. I also couldn't find the bulb size for the vizor mirror.
Thanks for the help :dblthumb: :bigthumb:
Chinaman_Chong
Car: 2009 2.5 CVT Altima Coupe w/ convenience package
i swapped out all my interior, trunk and license plate lights with LED panels
all the connections are the same and compatible with each other
as for the vanity/mirror i forget the type, but youre gonna need them in a 28mm length, otherwise they will be too large to fit
Eric Noa
Chinaman_Chong wrote:i swapped out all my interior, trunk and license plate lights with LED panels
Where did you buy the panels?
Chinaman_Chong
i got my panels off ebay for super cheap! search for "led smd panel" youre bound to find a connection that will fit
