help with intake manifold
m1dt0wn3
ok guys I just got all the bolts out all 7 of them in my ka24e and when I try to pry it off with a crowbar its just kinda budges. is there anything that I can use to help me get the intake off more easy? same thing with the exhaust manifold. thanks
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
Try removing the lower support for the plenum, then push the plenum down a little. Then the manifold should come out with a little moving around.
m1dt0wn3
sorry I'm not that good with terms...but what is the plenum?
slow s13
Car: cars, photo, music
its the tank part of the intake manifold right behind the throttle plate.
DoriftoMania
Car: car
make sure you unbolt every nut and bolts that holding the intake manifold to the cylinder head.once everything cleared away just sit your butt on it,it will falls off.........make sure you catch it ok! lol
