help with install FSB from racingline
All things Altima Coupe.
soxypoo
Car: 2008 Nissan Altima Coupe 3.5 ( gone )
2010 red G37X w/sportpackage
2012 sentra ser spec v loaded
hi guys anyone have racingline FSB please help .... i took 3 bolts off like in the instruction but i can't seem to tighten the bolt number 2 with the bracket on and so i tried to unscrew the bolt it won't come off. i can use my fingers to turn but it won't come off, i spent like an hour trying to this but i can't , i don't what happened and i didn't strip the bolt
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
I am confused, you cant tighten one of the bolts, but it wont untighten either?
Make sure you are doing things in the right order, the plates first, then the bar.. you need to thread them pretty good before bringing the bar into the situation.
try to move the car as little as possible because once those 3 bolts are out, i believe you can screw up the suspension by pushing the car (not sure though).
Is the plate on the right way? They gave me no issues bolting on, wedging the bar across afterwards needs some elbow grease, but its worth the effort.
soxypoo
i ut the block behind the wheel and make sure the car can't move anywhere before i start the project and i even pull the hand brake. i was trying to install just the bracket alone , i followed the direction and stuffs but ya i can't now unscrew the bolt... pissed off.BTW brian i emailed about the overlay but no reply
chiapetchua01
Car: 09 2.5s a/c cvt
LongBeachCoupe wrote:try to move the car as little as possible because once those 3 bolts are out, i believe you can screw up the suspension by pushing the car (not sure though).
i think what he means isthose 3 bolts are holding your strutso if you pop them out and somehow move your car enough and hit a bump of some sort, your whole strut will pop out which is something you don't want to see
so make sure that on both sides, you have a minimum of 2 of those strut bolts on,with 1 you risk hitting a pot hole, breaking that 1 bolt, then hitting anohter pot hole and kissing your suspension good bye
