help with info..
SlideSociety
Hey folks...i was just wondering...when building a KAT...what should i look for in the engine? like milage and such....i just dont want to spend the money trying to turbo an engine that will die quickly...so ur help would be much appreciated...thanks
TheOne
Car: 93 240sx FB
mileage, compression tests, leaks, abnormal sounds.oh and if it runs fine before the turbo.
SlideSociety
can i get some numbers? thanks for the help
MikeMurphy
Car: Guess
compression around 173psi across the board
Milage is just a general indication as to how worn parts on the engine are. Its not a science whatsoever. Personally, if it runs strong, does not make any funny noises, throw on a bit of boost.
SlideSociety
very cool....thanks for the info....so...as long as the engine isnt making noises and running nice...i could boost an engine tat has 130k miles on it?
TheOne
Car: 93 240sx FB
if you have done the regular mainteinance, sure......just don't over boost it.
SlideSociety
how would running about 7psi be? too much?
BadMojo
Car: 2007 Mazdaspeed 3
wishin4car wrote:how would running about 7psi be? too much?
7 psi is by no means high boost. What were you think of for fuel management?
Edit: I guess it's more appropriate to ask what your goals/use for the car will be.
SlideSociety
well, first i have to find one!!! (I live in PA too and its hard as heck to find one..lol) but, im just learning while i can so when the time comes...im somewhat knowledgeable...i think my goal is 300-350hp....any imput would be much appreciated...or hell...even if u know where i can find one!! lol thanks
