Help with Infinity G20 brake problem
solrey
Car: I
I just put new brake pads to all wheels. Now I can not take the air from lines in the FL wheel and RR wheel. Can any body now what can be. I am already bleed all lines including the ABS unit. I have not presure in these two wheels. Help please.
nametakennow
Car: '06 MINI Cooper S
I assume your fluid resevoir is filled up.
Did you mess with the lines at all? Might be a leak. Have you tried re-bleeding those two? Check all the line connections as well.
Infiniti
A very strange problem indeed.
solrey
Car: I
Thank you Infinity. But the problem i haved was that tha master cylinder was failing to puch liquid in these two lines. One thing a learn; in this master cylinder brake pump; the first seccion puch liquid to one wheel in the front and one wheel in the rear of the car.
But anyway i solved the problem changing the master cylinder.
nametakennow
Oh, gotcha, master should have been my first thought. It'd crossed my mind, but I was trying to figure out the exact problem first.
Glad to hear that you fixed it!
