chiken7 wrote:yeah...again, it sounds like you're on the right track.
didn't know problem with maf can cause all that havoc.
Q: did you open the ecu to look for burnt/melt/smoke marks?
Q: did you try cleaning your maf sensor after rewiring?
Everything inside the ECU looked good. No burn marks or anything but I still think it was bad because it was blowing the fuse. New ECU doesn't blow the fuse
MAF has been cleaned and it working properly.
The question still remains as to the fuse. Maybe someday someone will pull their 7.5a engine control fuse, turn the ignition on and see if it has power to both sides. Then I'll know. Until then I think it's just you and me on this forum.
