Help with identifying brake parts on a 95 Q45
Camel
Car: That would be obvious....
I am cross-posting from the infiniti tech section in hopes of a quick response from some of the Q45 gang.
Thanks,Chadd
I am having trouble identifying the service parts for a set of 95 Q45 calipers. I have found the pad retainers and caliper pins at NAPA, but I haven't found the boots that cover the caliper pins. Can anyone help me with a NAPA part number or a dealer part number to replace these rubber boots?
Napa carries a caliper seal boot, which i assume is for the pistons. They also carry a caliper bushing kit (inner and outer) that I cannot identify.
I appreciate the help.
Thanks.
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
I'm not one of the experts here, but I know that most on the Nico Forum will only use OEM pads on their Q. You should contact Joe for the Infiniti parts. I think it's the Pinnacle link of the advertisers. I've had non OEM pads on my Q and all they do is make noise. Get OEM.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Camel
Figured it out after many calls and a couple of trips to the parts stores:
NAPA Caliper Bushing Kit = Rubbers for the caliper bolt holes, contains enough to do 2 calipers
NAPA Caliper Hardware Kit = Metal retainers to fit the pads into the caliper brackets, total of 4, enough to do 2 calipers.
NAPA Caliper Housing Bolt - Front = Caliper bolts/pins to hold the caliper into the caliper bracket. Contains 2, enough to do one caliper.
Thanks for the advice guys. I just happened to get the time to hit a couple of stores at lunch to figure it out.
