blk240sx »
https://forums.nicoclub.com/blk240sx-u369.html
Sun Mar 06, 2005 5:17 am
Thanks boostfed, I will check for the check valve today.
Just a brief update ..
Turned out to be maf wiring. First disconnected the maf, started the engine and it idled fine intill i got on the throttle which caused an erratic idle. Connected the maf again, but switched the groung wires which did the trick. Idles perfect, gave a couple of blurps on the throttle, and engine returnes to idle fine.
Took her out for a ride around the block, with no hood, and noticed smoke. Turns out the turbo is blown If anyone has a RB20 turbo laying that doesnt need it hit me up.
Thanks
