skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Fri Jun 23, 2006 7:35 am
OK, its likes you may have a HICAS resevoir, but thats not a big deal. The big tube on the bottom of the P/S resevoir goes to the fitting sticking out the back of the pump (pink). The banjo fitting (blue) goes on the ps/s pump and goes to the regulator, mounted to the fron subframe braces by the radiator. From the regulator a hard line (yellow) goes to the steering rack, connecting to the front fitting. A hard line (red) comes out of the rack and goes to the front of the crossmember, loops around (green), and goes back to the resevoir. If that wasnt difficult enough, here are some color coded pics.
and your picture, with some colors on it:
