Postby
vstone48 »
https://forums.nicoclub.com/vstone48-u157854.htmlWed Jun 09, 2010 4:17 pm
Hey guys I want to remove my hicas from my 91 and I had a question. Now yes I did search a lot and found many helpful liinks but the help was all scattered so I was wondering if you guys can give me alist of eveything that I will need. I don't want to use a bar or anything I want to completly remove it. Please leave me a list of all the parts needed thank you. A list of everything from toe or tie rods (whichever) ,tubes to pump or whatever, i need everything im going to need to buy to do this swap. Thank you
Postby
vstone48 »
https://forums.nicoclub.com/vstone48-u157854.htmlWed Jun 09, 2010 5:05 pm
but if i was to switch them what would i need i just want to c how clean it can be swaped and stuff also would i need toe rods or what else other then just teh subframe thanks
Postby
bersh240 »
https://forums.nicoclub.com/bersh240-u144447.htmlWed Jun 09, 2010 5:24 pm
imo..
it would be alot easier to change the entire subframe assmbly instead of arm by arm swapping it over to the new one. if your going to do that might as well use upgraded multilink and/or press new bushings into all the arms. since its already apart...
Postby
vstone48 »
https://forums.nicoclub.com/vstone48-u157854.htmlWed Jun 09, 2010 5:25 pm
ok thank you guys very much, if anyone else knows please let me know asap thank you
Edit:
ok so i know to get the subframe, rear uprights, power steering lines, and power steering pump. Is there anything else please, i need to get thses as soon as possible so plz help
