Help with Headlights.
beachbum87
Car: 1999 Nissan Pathfinder LE
I recentley bought a 99 PF and have been having problems with the police. They keep telling me that I need to lower the beam level on the right headlight because it is to high. Does anyone have a tip or answer? Id really appreciate it. Thanks
fueler
Car: 2 Nissan's
2 BMW's
phillips head screwdriver
there is a small "gear" on the back of the headlight housing, that if you turn it using the phillips, adjusts the beam.
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
See pages EL-32 and EL-33 of the factory service manual: http://www.nicoclub.com/FSM/QX4/1999/EL.pdf (warning: large PDF file)
Each headlight has a screw that you can adjust to aim the beam higher or lower. If it's similar to my '03 and '04, then you'll need a flashlight and a long screwdriver / bit, because the screw is tucked away and tough to see (plus, you'll probably be adjusting the headlights in a dark environment). Once you know where the screw is, it's a simple five-minute DIY job.
Edit: fueler is right, it's actually a gear that fits a Phillips screwdriver, and not an actual screw.
