xsublimefrekx wrote:I am almost postive he said caps, i dont think he said shims. He did say they are to hold the cam down, but i still dont see why i wouldnt be able to get a new set.
If he said cam caps he is probably referring to the part that actually holds the cam in the head. This part forms the upper half of the bearing for the cam. It is not a good idea to interchange them as the head is linebored with these in place. Since every head is not identical. A small difference can mean that the clearance between the cam and the head bearing surface is wrong. Depending on how it is off, the cam could actually contact the head or the cap. Too big and it will not provide proper resistance to flow and the oil pressure can drop, and the other cam bearings can wear quicker. Thus causing more loss of oil pressure and eventually destroying the motor.
Of course if he is talking about the lifter shims, that is something completely different.
