compression »
https://forums.nicoclub.com/compression-u9345.html
Thu Jul 15, 2004 4:39 am
I question the effectiveness of those kits. 1 hp mod? You do realize that dyno runs vary from run to run by 3-5 hp usually, even if you dont change anything at all, and thats on a super consistent engine...I know this from LOTS of dyno experience.I am just an eternal skeptic I guess...but it doenst hurt to add more grounding to the system.
All you have to basically do is connect everything together. Find threaded holes on the engine/intake manifold/transmission or whatever you are connecting to, and wire it up. Use grounding points that are conveniently located for the wire lengths provided. The main connections you want to make (that already exist anyway) are battery negative to body, batt neg to engine head, batt neg to block, block to body, head to body, head to block, head to intake manifold, etc... Just connect everything together, be a little creative. Make sure that you get the head especially, thats where your spark energy is grounded. I also recommend paying a lot of attention to routing and securing the wires so that they are not just flopping all over the place.
