HELP with greddy FMIC for KA24DET..
andrewdees
Car: 97 Emerald Green SE
Hello, me and some friends are int he middle of installing the greddy kit on a 95 240. Everything is going good but we cant figure out how the intercooler pipes go. if anyone has a pic that would be great thanx!
-Drew
95 base
bruinbear714
andrewdees wrote:Hello, me and some friends are int he middle of installing the greddy kit on a 95 240. Everything is going good but we cant figure out how the intercooler pipes go. if anyone has a pic that would be great thanx!
-Drew
95 base
Let me know if you figure it out.. I have the kit sitting in my garage and the kit comes with about 7 pipes or so...
The bigger pipes go on the intake side, and the smaller pipes go on the hot side, if that's any help. :)
andrewdees
we finally figured it out last night, it took a lot of rubber couplings and hose clamps and cutting of the pipes, but we made it fit. i dont see how those pipes are supposed to bolt on. oh and we also removed the washer fluid reservoir. good luck with yours, now we have to figure out why ours isnt starting.
-drew
S-14boy
Car: 1998 Nissan 240SX SE
I figured out how the kit is supposed to go on last night for any of you who are interested. I did not cut a single pipe. The Big Elbow goes on the throtle body pointing down, then the pipe with the breather pipe goes on, breather pointing up. Then the pipe with the twist and bend goes under the frame, the bracket on it will line right up with the frame. Then use the lil "L" shaped pipe to conect to intercooler, short side on the intercooler. Your cold side should be done. Now for the other side. The big "L" shaped pipe goes on the intercooler, with the smaller side on the intercooler, then the "S" looking pipe conects to that pipe, u will have to cut a new hole to get it to fit, and use the pipe from the Turbo Kit to conect to the turbo. I finally figured it out after bringing all the peices inside thinking i was missing peices to count them out and take picutes of them so i could show Enjuku (where I got the kit) then as i was taking them out to my garage they just kinda fell into place. Anyhoot I will take pics to help out anyone else whos have trouble.
