j-z »
https://forums.nicoclub.com/j-z-u11653.html
Sat May 13, 2006 7:46 am
he says he already has a revhard mani. wastegate size shouldnt matter. they stay shut until you hit boost, and then it lets out the exhaust gases. you would have to get a custom adapter made to get it to fit on your revhard, or maybe drill and tap new holes as its a thick cast mani. for the egr you could easily get that to work. weld a bung into your downpipe, and cut the end of the egr tube off cleanly to where you still have the spinning threaded bolt that connects the tube to the mani on the stock setup. place that piece into your bung with some tubing still left on it. then get the same size and thickness tube and connect the dots. YO CHEZEDIK!! please check out the thread you made concerning z32 maf wiring as i have some questions that need answers. i would appreciate it. thanks and btw, jgs doesnt offer anything but an egr blockoff piece for the stock tube. i know cause i have one that i wont be using anyways. when i got it i was like wtf is this??
