help with fuel pump
USsil80
is there some kinda fuel cut off that doesn't let any power go to the fuel pump? i am not getting any power to my fuel pump ...the fuse is still good....but i can't figure out y i have no power to my fuel pump
tried search but found nothing....thanks...test for power at the plug comming into the fuel pump and no power
please help
Touchdown038
Car: Computers, cars, sports
Check to make sure the wire's not grounded out anywhere.
StorminMatt
I've only replaced fuel pumps in Hondas. But a 240 can't be too much different. If you are not getting power at the pump, you need to trace the problem back in order to find the problem. Fuel pump relays can be a problem. Especially in older cars.
240sxgirl
Car: Hot guys, fast cars, both at once.
Hey USsil80, its a little off topics but i was wondering if you still had those s13 ground controls for sale?
