If I ever have to remove it back to oem, I just snip the wires connected to the glove box light I am tapped into.Jape wrote:OEM part? to tap into your fuse box? and I dont want to splice anything other than what i could remove if i ever went to sell.
Really? Maybe only the SL's have them. My V has a glove box light.Jape wrote:there is no light in my glove box anyhow...
I wonder why yours are not working from the fuse box. Mine work perfectly and are connected there. I never have to worry about turning them on or off either, they are automatically on when I turn the key.Jape wrote:I think I get what you're saying NODES. It's just that currently all the lines are running to right next to the fuse box. Id really like to be able to figure out how to supply the power from there as opposed to re-routing the lines to the glove box light which im not quite sure how to get to.
He has the 1.6 which is a bare bone type car. That bulb and socket are almost $50 at the dealer.iluvmyVersa08 wrote:
I sure can!Jape wrote: Any way you could post a pic of how you connected yours to the fuse box?
Here are the pics I took this morning.Jape wrote:Wow car dealer can charge you any price they deem appropriate for the smallest crap. But yeah the lights are grounded. Ive tried just putting the wire in a fuse slot alone(didn't work), in along next to a fuse(didn't work), with a fuse tap(didn't work) so idk. Any way you could post a pic of how you connected yours to the fuse box?
No that is how my brother hooked it up. He stuck the ground into where that screw is since he had such a hard time finding a ground on the driver's side. It's been there since he installed them a few months back.NODES wrote:2nd picture is the ground wire coming lose on you?
It should of been shoved right behind the screw for a much better contact.iluvmyVersa08 wrote:
No problem.Jape wrote:Thanks for the pictures. Ill probably try tapping the same fuse, but whats going on behind that yellow tape? if it just a wire taped onto the fuse or something?
Lol, me too!VersaMG08 wrote:^----that's the main reason why I don't mess with electronics. Just let the professionals handle it. All those wires and fuses just freak me out.
