help with first start
stanza34
Car: 1993 240sx ka24det /1996 g20/2003 g35 sedan
hi i have a 93 240 and i just finished building and turbocharging it and i tried to start it for the first time this weekend and when i turn it over it has a rough idle for about 8 seconds then it dies and the throttle has no affect at all so i was thinking it was the z32 maf but i wanted to know if any one has any other ideas
DevilMB3017
So many questions...You give us the most info possible and we'll be able to help.
Did you change your injectors? Is your ECU modified in some way to handle these new injectors? Is your IACV hooked up? Is your MAF wired properly? Is your ECU tuned somehow for for the Z32 MAF?
These are just some basic ideas.
nissanfanatic
Car: 1992 Nissan 240sx SE
Distributor improperly aligned is one of the more common issues.
stanza34
yes to all of thee above
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
maybe you wired your z32 maf backwards? the thick white wire is the signal and the small white wire is the 12v. i wired mine backwards and flooded the hell out of my engine.
when you turboed your car did you touch your distributor or timing chain? if you did, then that might be off, even though you think its not.
Marko
