help with finding out size of rear speakers 93 coupe and how to replace
mopower
Hey everyone.Can someone help with the removal of the rear factory grills/speakers?Also, I would like to know what is the size of the factory speakers.
Info:The rear speakers blew out or shorted. Any suggestions on what speakers to get? No fancy setup. I have replaced the front panel speakers with kenwood.
T.I.A.
tRQmnsTR
Car: 1971 Datsun 510, 1989 Toyota Supra
1993 Nissan D21
4"x6" rear speakers.
http://www.cardomain.com/item/...=none
I recommend these just because you said nothing fancy and they are cheap.
mopower
Hey. Thanks for your input.Do you know how to remove the factory rear speakers?
ZiG
Car: 1993 240sx coupe
Fold down the rear seat and just pop the whole carpeted panel up. The grilles are attached to it, and it just snaps into place. After that's off, just unscrew the speakers.
ncs14
Car: 1995 240x se
pull the stock speakers out and cut a bigger hole for some 6.5s. they sound so much better than 4x6s
mopower
thank you for all your help.i will probably go for the 4x6, i do not want to cut anything ..lol
mopower
I just yanked out the speakers, and they measure 5 1/4 and about 6 1/4 with the frame. Where did the 4 x 6 info come from?
180fan
Car: 89 fastback
you have "active speaker"?
mopower
Yep, 100000 yrs old ..old speakers lol. They're ripped.
Kalypso
that datsun.... is sexy.
mopower
All,
Sorry for the delayed post, but I just wanted to thank you for all your help. I ended up fitting 6 1/2 round Kickers!
Kalypso
the front speakers are the same size correct?
180fan
Car: 89 fastback
4x6 in the front unless you chop up a piece of mdf and make a new bracket to fit the 6.5's. don't get a speaker with too much depth though, it can interfere with your window going down.
