help with final touches on sr install
sydways
Car: 1991 240sx Hatch
ive done all of the wrench work on my s13 black top into a 91 hatch and now need to piece together where all of the cut hoses and lines go.
question 1, what is the large hose barb on the rubber intake hose by the maf.question 2, what needs to read a vacum signal from the one hose barb on that same intake hose and what from the 3 hose barbs on the intake manifold by the throttle body.question 3, what is the hose that comes from the intake manifold by the throttle body. (i think it belongs on the cold pipe)question 4, is the turbo water cooled or oil cooledquestion 5, what do i need to do if i remove my EGR as far as the lines commin off of the valve cover etc.
u guys have already helped me 100 times more that my loser mazda tech friend. with alittle more help i might just see her run.
Jesse SR20
Car: 1990 S13 fastback
sydways wrote: question 1, what is the large hose barb on the rubber intake hose by the maf.
That is where you recirculate your bov. If you're not going to recirc, then cap it off.
sydways wrote: question 2, what needs to read a vacum signal from the one hose barb on that same intake hose and what from the 3 hose barbs on the intake manifold by the throttle body.
The barb closest to the turbo goes to the "T" on the valve cover. The barb closest to the maf is mentioned above. And the small hole on the back side of the intake tube gets capped. I used a corse thread machine screw, and screwed it into the hole.
sydways wrote: question 3, what is the hose that comes from the intake manifold by the throttle body. (i think it belongs on the cold pipe)
The large port near the throttle body does infact go to the cold pipe. It helps the motor idle.
sydways wrote: question 4, is the turbo water cooled or oil cooled
Both.
sydways wrote: question 5, what do i need to do if i remove my EGR as far as the lines commin off of the valve cover etc.
The EGR can be completely removed. You'll have to remove the hard tube that connects to the turbo extension, and cap that hole.
As far as the "T" on the valve cover, one side goes to the intake tube, and the other side goes to the stock oil catch can (the black can attached to the block above the turbo).
sydways
ur the man
